dueynetsell
Thread starter- Joined
- Nov 11, 2009
- 26
hey guys,
I am a college student with very little knowledge of boat engines, but with so little funds i have to pretty much do everything my self... so last winter my lower unit cracked due to water being in it (lesson learned), so i applied jb weld to the crack which holds just fine when i am only idling( which i am doing most of the time), but when i run it on plane for any length of time, a little bit of gear lube leaks through the jb weld...
Is this likely because i did not apply the jb weld as well as i should have?
or could it be that for some reason my lower unit is getting way too hot than it should be?
also what would be the best way to remove the jb weld if i need to do it again or finally get it welded?
