jet ski battery is dry
biglurr54
I my jet ski battery is dry as a bone. It is about 2years old and has been sitting in the jet ski for the last year and a half with no maintenance. I pulled it out for a stereo project and saw it was completely dry. There are no cracks or holes visible in the case. Should I fill it with water and give it a slow trickle or find some acid and refill it with acid. Or should I get a new battery because this one is most likely toast?
Re: jet ski battery is dry
i thought jet skis had gel filled batterys so you could turn them upside down? if its a wet cell battery and its dry then its done and needs to be replaced for water craft use.
