Rscardina
Thread starter- Joined
- May 3, 2010
- 513
"NOTE: If your engine has the "Fast Start" feature", you must disconnect/eliminate that feature in order to use the following method. The "Fast Start" automatically advances the spark electronically when the engine first starts, dropping it to normal when the engine reaches a certain temperature.
The full spark advance can be adjusted without have the engine running at near full throttle as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig a spark tester and have the gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4? less than what the engine calls for.
I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28?, set the timing at 24?. The reasoning for the 4? difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4?.
If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4? which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes."
After reading this in the sticky I had a few questions regarding this method. I am hoping someone could verify this for me..
When I go full throttle my timer base is snug to the spark advance rubber boot on the screw (adjustment)...if it is already touching at this point...do i need to adjst anything?? or move to the next step?
Can someone tell me what or where the 18 (or 14 ) degrees is read?. Is it on the flywheel??..and Do I use a timing light to view this number??
My flywheel is stamped with a whole bunch of numbers..on both sides of the cast in TDC.. so if I want spark at 14..is that in front of the pointer or behind the pointer while the flywheel spins.
Thanks
Thanks
