Joe Reeves
rkersh409
http://rapair.com/LinkClick.aspx?link=downloads/Metering_OIS.pdf&tabid=247&mid=789
Joe I got this off of a different site. Does it look like it is correct? If so I have some discrepancy's. Could you please take a look and see what you think?
On page 1 "Stator Input Clamp Diode Test" I get .46v on all leads when connected as picture shows. When I turned my leads around I get nothing on A,C,D,and F. But on B I get .84v and E I get .79v.
On page 2 "Stator Input Resistance Test" I get infinite on A,C,D, and F because my meter only goes up to 2M ohms. But on Pins B I get infinite and E I get 10K ohms.
On page 3 "Stator Input Impedance Test" I get 1.3M ohms on B and E.
On page 5 "Even Bank Kill Circuit Test" I only get .67v instead of 1.0 to 1.2v. Is this close enough?
On Page 6 "Odd Bank Kill Circuit Test" I get the same .67v instead of 1.0 to 1.2v
On page 7 "Temp Sensor Input Tests" I get 1.4v instead of 2.0v
On page 9 "Timing Sensor Return Line Tests" between A and C I get an infinite open. Instead of 220 ohms.
On page 10 "Timing Sensor LED Test" I get 1.3v instead of 2.2 to 2.4v
All these readings are with no battery connected or the rectifier unplugged totally. I am kinda concerned about the power packs readings on page 1. Also on page 9 where I am not getting the 220 ohms. What do you think?
Thanks again,
Robert
