Hi All,
I have been having an issue where the engine is jumping out of forward gear. I read about the clutch dog and forward gear on the forum. I took apart the lower unit the other day, and took some pics. Is this clutch dog and forward gear the problem, or might it be the pinion gear that has the teeth broken?
Also, when reinstalling the screw into the connector for the lower shift rod, I guess that I have to align the shift rod so that the divit in it is perfectly aligned with the connector hole? My friend was reefing on the screw, and the few couple of threads were stripped, when I took a look and realized that the divit in the shift rod was not aligned with the connector hole.
Also, where do I get cheap parts?
As a side note, I just realized that I have a bunch of friends in machining. could I get them to machine the forward gear and clutch dog?
Ivan
Ivan
