My 97 115 (J115gleuc) has been having fuel issues ( won't idle or run at speed unless bulb is pumped). Last time out the warning horn sounded a continous beep and no oil light came on, once when idling and once at speed. (oil tank was full) Shutting down and restart cleared the problem. The bulb and fuel line to motor are new, fuel filter on motor is clean, new Champion plugs and have replaced thermostat left side, as that bank never warmed up when testing on muffs. Had the boat 7 years with no issues. 2 weeks ago it would not run on the muffs without the bulb, My father came over to look at it several days later and it idled for 10 minutes without pumping. Now it's back to it's old tricks. Dad suspects fuel line blockage or tank vent. What do you think? Thanks for any help.
