Johnson 115 VLSSS motor mounts replacement
JoeFo86
Hey!
So I am going to be replacing my lower motor mounts. The mechanic told me that the motor has shifted slightly because they are shot. I want to do it myself. What do I need to know and do I need to remove the power head? Prop it up... ECT
This is a Johnny 115 2 stroke year 2000 J115VLSSS
I added a photo of the part.
jimmbo
I assume you are referring to part #6 in the Diagram. Remove the Cover #1, there should be a couple of Bolts(#19 on diagram below) holding it to the Mount Bracket #19 below, which is part of the Swivel Bracket #1 below, and it should slide out without too much effort
