Should I change them I rebuilt them completely but they are still acting that way I can run wide open but cold starting I have to keep hitting the electric choke to get it warmed up once I run it a minute it’s good crank right up but if fish a minute and try to start I either have to hit the electric choke and get it going again till idles long enough to put it in gear once in gear as long under load it runs fine and will plane off without hesitationThe electric primer is a valve.------It puts fuel directly into the back of carburetor throat.----This fuel bypasses the carburetor metering circuits.-----This suggests that carburetors need attention !
