johnson 120 wont idle
hoeser
Re: johnson 120 wont idle
If the water coming out of the tell tale is that hot I would be concerned. Use a temperature gun on the heads. You want 135-145F when they are warmed up. If the tell tale water is hot that is usually the sign of low flow.
