Re: johnson 140 v4 vro pump rebuildable ?
kennyfam : the reason i think it is the fuel pump is the way it was acting it would run ok for a minute or two then it would cut out pumping the primer it would pick up again then after a couple of those the oil warning beep (everyother beep)would come on it would still be runing ok though ,, i would shut it down wait for a bit acould do it all over again ,, made for a long run home that day ,, i was low on oil that day but not out ..... it did't matter if going fast or slow same thing happens ..at home and full of oil i was trouble shoting at home same thing .. i took a spair piece of hose and ran it off the gas oil out and when sqeezing the primer gas comes out,, fire it up and nothing while it's running .. i had replaced this pump 3-4 years ago because simlar problem and it had been fine tell the other day when this started... ,,, it's a 1985 140 v4 on an 16.5 ebbtide alot of fun when running any help would be greatlly appercated thanks
