I bought an '80 Johnson 15 that had sat for a couple years. I got it started fairly easily but it had some running problems that were persistent. Sometimes when accelerating toward WOT it would stumble and the revs would drop. A second try would usually get it to go to WOT although I thought the engine was not putting out full power at WOT compared to my '77 Evinrude 9.9 converted to a 15. Also, upon decelerating from WOT, the engine would usually bog and stall requiring a re-start. Once started, there was no problem idling in as the engine idled very well.
I pulled the carb out and found that it was gummed up pretty bad inside indicating that the engine had not been properly run out of gas and fogged and that gas was allowed to sit in the carb for long periods of time and go bad. Besides varnish, there was also some light brown powder in the bowl which I also cleaned out.
I cleaned up the bowl and replaced the needle valve, float and two brass bushings from a used but ultra-clean 9.9 carb that I had sitting around from the conversion I did on the '77 9.9. All the parts I switched into it were compatible and no different from what was in the '80 15 carb. I also pulled the low speed adjustment needle out and replaced the seal/grommet around it with the one from the '77 carb and cleaned out the channel it screws into with a spray of carb cleaner.
After reassembling and re-installing the carb I have a different problem. The engine starts very well, it idles and trolls very well and you can rev it up high in neutral very well but when you put it in gear and try to accelerate to WOT it will start to gain revs and just as the boat is about to plane and the revs really start to pick up, the engine just dies (stalls). Obviously, not enough gas is able to get through to allow the engine push the boat beyond a certain speed and when the timing advances to a certain point, the mixture is leaning out to the point where the engine stalls.
When I worked on the carb, I did not knock out the Welch plug and do any cleaning in there. Could some crap in there be causing my problem? If the used seal/grommet I used for the low speed adjustment needle is not sealing, could that cause the problem I'm now having?
Thanks in advance.
Thanks in advance.
