Johnson 15 hp
Riverrat47274
Re: Johnson 15 hp
Got motor back running.runs good at an idle.but won't wants to die shortly after rpm's pick up.not sure if its getting enough gas to pick them up.any suggestions on tuning from here?
ronward
Re: Johnson 15 hp
Does it have a high speed needle as well?
Riverrat47274
Re: Johnson 15 hp
No just slow speed.i did notice the cam follower roller has a little wear on it wear it makes contact with the timing tab.could this be causing the carb butterflies not to open far enough and not allowing enough gas into the engine?
Tom Maslar
Re: Johnson 15 hp
The amount of lift lost on the deteriorated follower is directly related to the amountt of wear--probably not a whole bunch. Check the routing of the spark plug wires. if they bind they will hinder the travel of the throttle to the stop. Make sure you dial in the follower first.
