Johnson 150 Fast Strike Power Trim Question
xX_Devious_Xx
I have a question.
Where does the power trim connect at for the controls on the motor? My wiring didn't come with a plug so I have to run separate wiring for it and I have no clue where the plug or connections on the motor is for it. A picture would be very helpful so I can see what I am looking for. Thank you for any help
Bad Al
Look on the powerhead for a small black rectangular plastic box. That would be the PTT relay junction box. There should be a wire leading from it with a plug in type connector containing two wires... one green, one blue. That's where the electric motor should connect...... color coded, green to green... blue to blue.
xX_Devious_Xx
Are you replacing the tilt pump motor?
no I am not replacing it. I bought the motor 2nd hand to replace one that went out on me. Wiring harnesses were different and the one for the Johnson didn't have the plug for the power trim so I have to run wires for it
Honorary Supreme Mariner
Model # of your old motor ?----Model # of your replacement motor ?
Faztbullet
See post#4..relays and wires on top of port carb,wires run down behind air box.
xX_Devious_Xx
I am not around the motors for the model numbers. I am at work, old motor was a 97 Evinrude 70hp and the Johnson is a 97 150hp Fast Strike V6. All I can say for now but if needs be I can get the model numbers and post them tomorrow
Those used the same wiring harness I think.----Same colours for sure.-----Just a matter of finding the plug on the motor.
xX_Devious_Xx
Pics I took of a plug that's on the port side of the motor.
That is the correct plug.------Red is 12 volts+-----Green is for GRASS ( down ).---Blue ( sky ) is for up.----Other wires for trim gauge.
xX_Devious_Xx
ok thanks. Im gonna try to work on it on my days off and get it working. I haven't had a chance yet in a few weeks
