johnson 150 fast strike
assassins42
getting ready to buy a 2000 model 150 johnson fast strike anything i should know about this engine. are the good engines or do i need to stay away from it
bob johnson
Re: johnson 150 fast strike
they are great engines, but those are the down years right before they were bought out. But at this point any issues would manifested themselves by now.
bob
assassins42
he put new fuel pump on 1 year ago. checked compression they were 110, 110,105,118,118,110
bob johnson
no knocking noises , good compression, and a clean, smooth lower unit is the basis for a solid outboard.... all the other little kremlins are easily fixed usually....
or not nearly as expensive to fix.....
the carbs leak often...because they are plastic and the brass ball sealing a construction passage becomes lose.
good luck
bob
boobie
As long as it's got carbs it should be okay. The only thing I can remember about that model year was they had some gear case probs but that should have been cured by now.
