Johnson 150 faststrike 1995 Oil Alarm
cdnfthree2
Hello, My low alarm sensor is going off every 20 seconds. The motor seems to run fine and is using oil. How do I fix this? Is this a motor issue, an oil reservoir issue, or shifter problem? Thanks alot
cdnfthree2
Re: Johnson 150 faststrike 1995 Oil Alarm
The only info I find useful in the SELCO manual is to pull float from reservoir and see if its stuck. I'll try this first.
