hogan12009
Thread starter- Joined
- Apr 4, 2013
- 33
Johnson 150 1999 is running really rough then just stalls out. Initially I thought it was the shift interrupter switch as it was stuck. I disconnected this switch and it started right up. revved a couple times on the hose then stalls out. sounds like its coughing for fuel then dies. I then have to prime the bulb to get it to start and it will rev once or twice then coughs out. The primer bulb used to stay hard after I pump it for hours now it goes soft in about ten minutes. it does go hard when I squeeze it. I was almost thinking fuel pump because pumping the bulb and it ran normal for a few seconds then coughs out. I re pump runs normal for a sec then coughs. and then back to the soft primer.
I noticed the timing mechanism isn't advancing when I rev it up. I have seen this move in the past with revs now nothing. when I advance it by hand it revs up for a few seconds and coughs out. This engine usually runs really well and this just started out of the blue. Anyone that can point me in the right direction would be great.
