Johnson 175 Motor wobbles
ScraggyNeck
I have a Johnson 1988 175 HP. The engine seems to wobble. I think the upper motor mount is bad. Is there any way to check this without taking the Power Head off? I just purchased it and the previous ower said he used it that way for two years. The engine is very clean, no rust. Any suggestions?
Dhadley
Re: Johnson 175 Motor wobbles
While the upper mount could be bad the nut on the bottom of the steering arm assembly could be loose. Check oput the parts diagram at shop.evinrude.com to get an idea of what we're refering to. The nut is on the bottom of the steering arm assembly down by the lower motor mounts.
ScraggyNeck
Thanks,I see what you mean. I will check to see if the nut is loose when I get to the shop. If so, that would be an easy fix. The engine is currently sitting on a stand and move back in forth very easy, almost too easy. I did notice when the engine is at its stop either all the way left or right it is still moves a little, either this is the shock working properly or damaged? I have other engines that do not have this slop in them, they are much tighter. Maybe tightening the nut if loose will fix my problem.
Benny1963
lowerunit removal ,
there is also a bushing in the top and bottom has retainer .
when i built my 175 it had a lot of play so i rebuilt mid sec .
took forever to get the parts top mount is under powerhead .
Dhadley
It's not a bolt, it's a nut on the bottom of the steering tube that runs up and down. The nut is down by the lower motor mounts. You might be able to see it from up underneith the lower mount area.
ScraggyNeck
I remove the four bolts on the lower motor mounts. The engine seem very loose. How much play should there be with the upper motor mount still connected? Also, I cannot see the Nut. What is needs to be remove to get to it?
ScraggyNeck
Is there anyway to check the motor mounts without pulling the head and lower units? I hate to do that if there is a an easy fix.
coolguy147
hows ur spark fuel mixture and compression?
sometimes if ur too rich or lean the motor will vibrate
no spark will result in a cylinder not working and providing un equal force.
and at idle the engine my vibrate to stay alive since the fact that u might have poor compression
some thoughts?
ezeke
The nut is #13 at the bottom of the steering assembly. You have to drop the gearcase to work on it. Click the thumbnail, please.
Dhadley
I'd almost bet on the nut being loose.
ScraggyNeck
Thanks, I will check the nut to see if its loose. I will let you know. As far as the engine vibrating, you can feel the wobble just moving it back and forth.
ScraggyNeck
Dhadley you were right....Nut was loose. Thanks for the help.
ScraggyNeck
Yes, it tighten right up. Thanks again for your help.
