1985mariner20
Thread starter- Joined
- Nov 23, 2012
- 24
I have a 77 Johnson 175 that started giving me trouble today. after coming to a stop and fishing for a little while, boat would not go forward. It would just rev high and not go in gear. I tried to go forward several times with no luck. I decided to put it in reverse to see if that would work and it did. After getting the boat into reverse, it would not go back into neutral or forward. Completely stuck in reverse. I pulled cowling and inspected linkage while moving controller from forward to neutral to reverse. Everything seems to be functioning properly so I pulled the pin on the shift linkage and tried to manually shift into forward. The shaft is moving up and down as normal, but nothing is happening in the LU. No matter where the shaft is, the LU stays stuck in reverse. Any ideas on what the problem is and how to fix it?
