Re: johnson 175
As long as the motor is stock, as produced, 87 will be fine. Thats assuming the heads havent been cut, youve got the right spark plugs and the timing is set correctly. <br /><br />Thats impressive for the small diameter Renegade. It'd be real interesting to try a larger diameter prop. <br /><br />Great rig. Should be a lot of fun. Nice to see it doesnt have hydraulic steering. Basically its a pad bottom hull. The flat part of the V is like a ski. At speed you have to balance it on that ski. It takes a staedy hand and requires a good "feel" in the wheel. You'll get it. Just take your time. Theres nothing like the feel of a boat up on the pad.
