Markstang
- Joined
- Sep 17, 2010
- 29
Hello,
As you can see I am new here and have been lurking for a little while.
My lower unit has two plug holes , one lower and one higher. I know to change the plug seals every time these are accessed. My question is regarding changing the oil. Do I fill it from the top one? How do I know when to stop? ...or do I fill it from the bottom till it comes out the top?
One more thing. The fluid that came out of the bottom when I barley pulled the plug was...a 1/8th teaspoon of water followed by almost pure white liquid. It was so white I am thinking there must be some kind of lube that is white. It did not seem bubbly.
I want to rebuild the lower impeller and seals. Do I order these from who? OMC or are they just the same here.
Thank you for your time.
Mark
Mark
