Johnson 1961 10 hp
Thebone
My motor starts fine but in the lake it bogs at full throttle I pump the ball and it acted like it wanted to go but didn't then the hose at the tank came off ( kick it or something ) but as it started to run good then run out of gas any Ideas
OptsyEagle
Hose coming off at the tank is a good place to start. Get that on there so it stays on and try it again. Sounds like a fuel starvation problem and a disconnected fuel hose will tend to cause that.
Thebone
It run like that for a long time on the way in I Was pumping the ball when I kick it off but not on purpose
then it started running good .feels like it went straight to go but won't
Thebone
Like all motors they run great when there running out of fuel
oldboat1
Repair the line, and replace the fuel pump. Square pump and gasket will work -- Ebay for a used pump and a rebuild kit, if you want to go that route.
tomhath
Master Chief Petty Officer
Might have been sucking air because it wasn't connected properly.
I assume you have fresh gas in it (this time of year a lot of motors run bad on last year's gas), and had the tank vent open. Try hooking it up again and see if it runs, but starving at wide open throttle often means the fuel pump is starting to go.
