austin7777
- Joined
- May 2, 2010
- 8
Hi all,
I want to install a tachometer on my 1980 Johnson 85HP V4 outboard (J85TLCSA) and have a few questions:
1. After reading a few posts on this forum it looks like the remote control has a plug on it that is made for attatching a tachometer (see picture 1). What I want to know is, is that what this plug is for ?, and is there a way of testing it before I go to the expense of purchasing the tachometer and wiring.
2. I also want to open up my remote control and check the above plug to make sure it is connected, and to check the overheating horn as it does not seem to work, How do I go about opening up the remote control ?, I have taken out the two long bolts and the remote control arm but am still having trouble, is there any hidden bolts or trick to it (I have attatched two pictures of the remote, as you can see I have drilled a hole in the top left hand corner as I thought there was a hidden bolt, but couldnt find one)
Thanks in advance
Thanks in advance
