JOHNSON 1983 50HP 2HOURS ON IT
JOE05
JOHNSON 1983 / OUTBOARD / 2 STROKE / 50HP WITH 2 HOURS± AND WINTERIZED THAT YEAR AND PUT AWAY<br /><br />It started the other day with the first turn of the key. Testing it in fresh water after about 20 minutes into the ride, a siren noise came on out of the throttle box area. What did this mean?? I trailered it immediately. Now I ran the motor at home for a good 20 minutes also a couple of times and had no noise. This motor purrs like a kitten!! <br /><br />Another quick question... <br /><br />CRIS CRAFT 'CORSAIR'/ 1966 / 16 FOOTER / HAVE THE ABOVE MOTOR ON IT<br /><br />How can I get the front of the boat down? The motor is as low as it can go in the angle department and man does the front rise when I go fast.. its almost funny. Now when I bought the boat two weeks ago it had a 90 HP on it so its not the weight. It didn't level off either. <br /><br />I have been in other boats plenty of times but this is my first to own. I'm learning as much as I can as I go. Its funny, I know more about fishing then boats.<br /><br />THANKS IN ADVANCE... <br />SIGNED 'THE EMPTY WALLET'
JOE05
Re: JOHNSON 1983 50HP 2HOURS ON IT
WARNING HORN ... for over heating?? I just saw that post.. overheating from what though??
Goodoleboy
Welcome to the forum!<br /><br />The impellar has dried and become hard and brittle with age. No longer pumping water. Or at least not enough to cool engine.<br /><br />Thermostat could also become stuck closed over time.<br /><br />Replace impelear first thing you do. second at least check to see if thermostat is opening. Test in water heated to at least 175 degres.<br /><br />Congrats on your lucky find.<br /><br />Good luck!
JOE05
Thanks for the response... will let you know how it goes.
