Hi, I am trying to sort out the temp sensor wiring on the above engine. There are 2 sensors (1 on each head) which connect to a tan wire.. Am I right in assuming the sensors are open circuit and short to ground when overtemp? Also I found a 3rd tan wire which was not connected, this was close to the main multiconnector (left side/from prop) does anyone know where this goes, is it for a temp/pressure guage?
Thanks...
Thanks...
