Johnson 1985 140 hp not charging
Bobby D.
As I posted earlier "that I would check for bad diodes in my rectifier" I found that the yellow wires from my water cooled rectifier has current flow in both directions. Also, that the others wires have some ohm value that are connected to the rect. I believe there are a total of 5 wires coming from the rect. What should the ohm values be on the wires? Thanks
