Dale Meyer
Thread starter- Joined
- Aug 2, 2016
- 12
I bought this motor new in 1988. I had VRO bypassed by a reputable boat sales/repair place in about 2002. I had major engine overhaul 2004 after a relative failed to use 50:1 mixed fuel. So since the rebuild the engine has run well until a month ago. Then it would want to quit at or near wot after about 30 seconds. It would run indefinitely at lower throttle. Then it stopped running at all. I replaced the aftermarket filter/water separator. I removed the in-line fuel fuel filter. Fuel is getting from the tank to the carbs with no restriction. So I bought a new Sierra 18-7352 pump. Now I am new to this, so when I went to install the new pump I found the pump was mounted to the intake plenum with no connection whatsoever to the proper location on the crankcase. So how in the @*/## has this motor ever run? Has anyone ever seen such a situation? I'll try to post some photos. Having difficulty posting images from this Android tablet. My email is dgmcrm@yahoo.com if anyone wants a photo of this situation.
