The engine pushes the boat (16 ft, aluminum Bass Boat at 26 MPH, 4000 RPM). <br /><br />The Model No. is J40E1 CEC SN G02338686.<br /><br />It will reach 30 MPH at 4200-4300 RPM but bogs down, but runs nicely at 4000 RPM per above.<br /><br />It will not idle more than approximately 20-30 seconds.<br /><br />I can depress the Electric Primer on the Remote Control and it will keep idling.(approx 1000 RPM)<br /><br />I can put the Manual Primer Valve to the Manual position and it will keep idling (approx. 1000 RPM) <br /><br />I havce disconnected the VRO and capped the oil inlet and am pre-mixing 87 octane Unleaded Gasoline atthe Ratio of 50::1 with Pennzoil Premium 2-cycle engine oil.<br /><br />I have the SELOC Manual but can find no Carberator that fits what is installed on my Engine.<br /><br />It is close to a Type IV, has Fixed Low and High Speed Orfices and a Needle Valve which I'm assuming is for the Intermediate Speed.<br /><br />Any advice or suggestions you may have will be greatly appreciated.<br /><br />Thank You,<br /><br />Gerry Smith
