johnson 1991 35hp
allan93
help please.. my engine starts fine idles fine trolling not a problem anytime i give it throttle its last maybe up to 15 mins then starts to bog or jerk (not sure how to explain it) i reduce throttle and it idles and trolls fine...any ideas
tashasdaddy
Re: johnson 1991 35hp
is the vent open on the fuel tank. fuel pump cannot pump out of a vacuum. plastic tanks, had a knob in the center of the cap that has to be open.
allan93
yes its open ...replaced plugs and fuel filter and had the carb cleaned
tashasdaddy
does it feel like you hit something? may a submerge log, does it bang or make a noise?
allan93
nope doesnt feel like its hit anything the engine just starts to jerk ater a little while on 3/4to full throttle and loses power so i reduce the throttle and all is fine on idling or on very slight throttle
tashasdaddy
next time it does it, immediately check you spark. does having someone pump the fuel line bulb help keep it running.
allan93
the engine doesnt cut out at all but ive tried the the bulb with no diffirence
chewie1997
possible a dirty fuel line preventing the fuel needed approaching WOT?
tashasdaddy
it runs 15 minutes at WOT, then bogs, that is why i suggested spark, coil could be heating up and failing, the motor would still idle on one cylinder.
allan93
hi all ..i replacedthe ignition coils on the engine and was out today for 2 hours no problems
Al-53
Glad to see your up and running again....Tashasdaddy hit it right on...
I follow all the 35HP threads as I have one also..so your problems may help me in the future...
glad your cruising again
Al
