nikoweb1969
Thread starter- Joined
- Aug 13, 2022
- 8
Charge the battery and have battery load tested.----Fact---If flywheel turns slow there will be no spark generated.
these are cranking tests. might be hard to start without sparkthanks, do I have to do the measurement with DVA only by turning the starter motor, or with the engine running?
however if I have an open circuit in the stator, I think there is definitely no voltagethese are cranking tests. might be hard to start without spark![]()
