Crashtackle
Thread starter- Joined
- Nov 25, 2009
- 29
Hi,
After reading some posts I am starting to think there is a connection between a charging problem and a tacho problem. I have hept my batteries fully charged. I have only owned the boat 6 moths and it has about 220 hours on it and the motor is well serviced and runs really well.
I have noticed that the tacho has been intermittent and work at times but on my last trip off shore the tacho did not work. I was using one battery and with the sounder,and radios on for 6 hours, the battery was flat when ready to come home. I switched to the spare battery and come home.
I voltmeter did not come up over 12 volts on the return home.What voltage should the charging system reach when working properly. I started the boat up at home and disconnected the batteries to see if the system would keep running on the charging system and, the motor still kept running with no battery connected so, something is working and maintaining voltage, but still no tacho.
As I live in the country and about 100 miles from the coast and a marine shop I have ordered a ampmeter to wire in to see if I have a charge. I am still waiting for the ampmeter at this stage. What amps and volts should the 150 Johnson charging system put out to be considered acceptable or what would be causing the charging / tacho problem.
My gut feel is the problems may be connected. I have checked all the fuses and okay. I want to get it working before I take the boat out again.
Thanks for reading this and I hope you have a solution for me.
Pete
Pete
