Johnson 20 hp
Nick S
Hi,I've just acquired a Johnson 20.Model No 20 BRL73A,serial No B 2473.Can you tell me anything about it?Unfortunatly it is seized at the moment,can I get parts,if so are they expensive?What mix does it use?I also need a tiller arm for it!A lot of questions,but I appreciate your help.Thank you.Nick
Down South
Re: Johnson 20 hp
It's a 1973 model. You should be able to get parts for it. The gas/oil ratio is 50/1. The tiller arm, you might be able to find at a outboard repair shop. They usually have an outboard graveyard and you might luck up.<br /><br />Good luck
