ranger1850v
- Joined
- Jul 29, 2012
- 22
Is 70s comp to low on an 87 gt200? And I have a racing mid and lower unit with an exhaust relief on the mid. Is stock jets acceptable?
You have a 15" midsection?? Sounds more like a stock midsection with a bolt on "cow bell" and nosecone added. It will be slow out of the hole as it has no back pressure and on a heavy ranger just hurts it more.. 70 psi is pretty low on a 2.7L engine and from your other posts the only way it would turn a 27pitch would be in a 4 blade shooter and still thats a little much., a 3 blade with your set up should be a 24 pitch raker or 22 turbo and cap the exhaust off as all it does is makes noise and add very little hp unless you turn it over 6500rpm which it wont live at.I have a racing mid and lower unit with an exhaust relief on the mid.
Need to check jetting as gutting the airbox makes em run leaner...lso noticed none of the guts are in the airbox?
