mjfrederick
Thread starter- Joined
- Jun 8, 2012
- 36
I have a 1990 Johnson 200 that I am trying to change the water pump on. I have removed the 4 obvious bolts (then put them back in just a few turns), the trim tab and the bolt under it, and the bolt on the anode (just in case, wasn't sure if that went through). I have disconnected the shift rod. The lower unit won't budge. Not a millimeter. I've tried using a rubber mallet to work it loose, but it just won't go anywhere. Any thoughts, tips, tricks are appreciated.
