Johnson 200 VRO alarm
moodyscruz
I have a 1993 200 with the VRO in place, but the alarm keeps going off indicating that it's not getting enough oil. So I've been mixing myself at 50-1. I'm trying to avoid having to pull the boat out of the water and take it to the
mechanic. Is there any thing I can check or disconnect? Maybe unhook just that part of the alarm untill I can get it to the shop. The alarm stops if I up the rpm's so it's only sounding at idle. Is there a fillter or a screen that could be cloged? The level in the tank is going down so I know it's getting some oil but I don't think it's getting enough at idle.. Thanks
jonesg
Re: Johnson 200 VRO alarm
Theres probably a sock filter on the oil pickup but the alarm wouldn't likely go away with higher rpm's. I'd suspect the pulse fitting that powers the pump, do you get any alarms at WOT?
Do a close inspection of the vro pump, pressurize the oil bulb and look for leaks. Sometimes a small flashlight makes it easier to see.
Did you purge the oil line of air when you connected it to the engine fitting?
It has to be pumped until the oil starts to come out the line, then connect, otherwise you'd get a bubble that goes back and forth setting off the alarm.
Get yourself the service book , even if you take it in.
www.outboardbooks.com
Interesting problem though.
You can run on premix for a while, plugs will probably foul and it will need decarbing. A wider gap, set to .040 will help with the plugs getting fouled.
d.boat
I don't understand which alarm you're getting. Is it the "no oil" (rapid beep, every second or so) or "low oil" (slower - every 20-30 seconds).
As far as disconnecting the alarm - it's very easy and as long as you're premixing, it won't do any harm to disconnect the alarms, and there is no rush to get it fixed. But, if you're premixing and also getting oil through the VRO/OMS system, you're wasting oil.
You can easily monitor actual oil usage by simply marking the oil level in the oil tank, filling the fuel tank completely full, running long enough to burn 5-10 gallons, then refilling oil to the mark and fuel to completely full and figuring the oil usage per gallon gas burned.
Disconnecting the alarm: If it's the "no oil" alarm, unplug the 4 wire cable that comes out of the fuel pump itself. If it's the "low oil" alarm, disconnect the two wire plug that comes up from the oil tank and connects inside the engine compartment. Just secure the loose ends and/or tape them so they don't bounce around and possibly short to something metal.
Let us know which alarm it actually is and there might be some suggestions for actually solving the problem pretty easily. Could be as simple as the oil line losing prime because of a loose connection, a partially clogged oil pick up filter, stuck oil tank float switch, etc.
I once had a sporadic problem with the "no oil" alarm sounding at idle, which would go away with a squeeze or two on the oil primer bulb. I knew it was getting enough oil because I monitored it as described above. I went through the oil line routing and connections, and haven't had the problem since. I also carefully re-primed the oil system (it's easy). There was nothing obvious, and I really thought the system had been properly primed before, but something in there - either an air bubble from inadequate priming, or a tiny air leak - that was causing it to lose prime, just slightly.
OH! and the obligatory mention of this excellent article on the VRO/OMS system! http://continuouswave.com/whaler/reference/VRO.html
moodyscruz
Thanks guy's, I know it's the no oil alarm. It's the beep beep beep not the beep every 30 seconds or so.. I did check to bulb and it's stays hard all the time. I'm thinking that if that sock is cloged a little while idling it's not sucking hard enough to get enough oil through, but under higher RPM's it's pulling enough oil through to satisfy the sensor.. I did check the line's and there doesn't seem to be any leaks, My mechanic did give me a different sensor that I changed but it didn't help.. How do you bleed the system I can take the hose off that sensor and squeeze the bulb?
d.boat
Never hurts to replace the pickup filter. Might want to take the opportunity to completely empty and clean the tank and see if there's any sign of moisture in the oil you get out.
OH, by the way, when mine was giving me that no oil alarm, the oil bulb was indeed hard, I had to squeeze it pretty hard, but a couple of squeezes would make the alarm shut off, even at idle. It didn't seem like it would be doing anything since the bulb was so hard to begin with. It would tend to go away on its own at higher RPMs, like yours.
But that doesn't make any difference because it doesn't hurt to change the filter, and when you do you need to re-prime the system anyway. So whether it's a clogged filter (pretty unlikely in my opinion) or an air bubble or such, it really doesn't matter.
To reprime:
1. Put enough oil in tank to cover the pickup filter well and keep it covered when you pump out about 1/2 pint or so, but don't put too much in there so you can test the low oil alarm while you're at it. (see below). I think 1 1/2 quarts should be adequate. Use your judgment.
2. disconnect the oil line right at the VRO/OMS pump. Mine - and I assume all VRO/OMS pumps - has a little clear-ish plastic section just at the pump. You disconnect below (downstream) of that.
3. Pump the bulb until oil flows out of the end you disconnected and catch it in a jar. Obviously, keep pumping well beyond the point you get your last air bubble, I pumped a good 1/2 pint or more into my jar just to be really sure. Your goal is to get all the air out of the entire length of the oil hose. Assuming the jar is clean, after you're done you just put it back in the oil tank, maybe after testing the "low oil" alarm (below).
4. Reconnect and clamp the oil hose
5. pump the bulb until you see that clear section fill with oil, then pump two more firm pumps. The bulb will probably feel pretty hard this whole time. It doesn't get nearly as soft and pump up firm like the gas bulb.
6. Before you start this whole thing run some pre-mix so that all your fuel hoses are full of premix so you won't ever be running raw gas until you're sure the oil mixing is working is good and you have finished testing the "no oil" alarm (below). After everything is done, I run about 5-10 gallons of premix in my built in tanks. If you have portable tanks, most of a 6 gallon tank should be plenty. Then measure carefully how much oil and gas were used to see if the ratio is about right.
You can take the opportunity to test both the "no oil" and "low oil" alarm.
The "no oil" is tested after you've disconnected the oil hose, but before you do the purging. Run the engine (high idle on the hose or in the water) with the oil line disconnected but temporarily plugged. The no oil should sound after all the oil in the pump and adjoining lines is gone. It might take a few minutes, but remember, you're running premix so no harm. Stop the engine and do the purging. After you connect and finish purging, when you run it again, the no oil should stop after a short while.
To test the "low oil" alarm, when you fill the tank after changing the filter, just put at most 1 1/2 quart in it. Enough to cover the filter and keep it well covered while you purge it, but not a lot more. I'm not sure, but I think the low oil sounds at about 1-2 quarts remaining? It needs to be low enough level to activate the "low oil" alarm. When you run it after purging, the "no oil" alarm will stop as above, then listen for a minute or so and the low oil alarm should sound ever 30 seconds or so. Then, fill the tank with more oil and that alarm should quit.
If you're not getting the alarm, you might have too much oil in the tank and you can remove it a little bit at a time with a turkey baster (again, saving it.... it's perfectly good still as long as you keep it clean). Make sure you don't remove enough so that it sucks air because then you'd have to purge again.
Again all this is done with pre-mix gas until you're sure you've got the thing connected and purged right and it's sucking up oil at the right rate.
All of this is in the shop manual (including the alarm tests, how much oil to have in the tank) and I think it's also in the basic owner's manual. I think they are invaluable and recommend them.
moodyscruz
dboat, thanks for the advise I'll do the reprime thing this weekend and change the pickup filter.
d.boat
It probably took me as long to type it as it does to actually do it - hopefully you can tell it's really a simple thing which doesn't take very long.
lrbennett76
I have also had the same problem but I get the long 10 second beep and no oil light. I followed the steps above and I still get the no oil light and long beep. Now what do I do? I have a 2000 Johnson 90hp.
