Johnson 20hp 1973 carburetor
Pajala
Hello. I wonder where to find? Mine is broken so i need to find a new one. Do you know what they are called or where to find they?
It is called a NOZZLE.-----It is not the high speed jet---Normally that part does not require replacement.----What happened ?----Your location ?
The above parts breakdown does not list the nozzle or a replacement carburetor.------Easy fix for this problem here.-----But the poster is overseas.
oldboat1
I believe the nozzle is an integral part of the carb top half -- would have to find a donor carb with an intact top half. Did you remove that nozzle from the carb -- and what is that reaming device pictured? Is that in a vent? The nozzle drops into the the elongated female tube built into the carb bowl (that part visible in the diagram).
