Rodznreelz
Thread starter- Joined
- Oct 4, 2004
- 17
I have a 1996 225HP Johnson ocean runner. Since i've had the motor, it has always been a trouble to start. It usually takes 3-4 minutes of repeated cranking to get the motor to crank. This past weekend the motor refused to crank at the launch. I pulled a couple plugs and they were both soaked with oil and gas, as you would expect. About 10 minutes later, the motor attempted to start. Finally, after repeated cranking, the motor started and ran fine. Why is the motor neglecting to start everytime it is cranked from a cold start. It would seem that the motor should crank within 5-10 seconds upon initial key turn. If anyone can help I would appreciate it.
