Johnson 225 outboard tbl
wayne robinson
Johnson 225 horse ,starts ok idles, when i put it in gear and apply throttle it dies a couple of times before i can throttle it up.always starts back up? Carbs have been cleaned -no help! Seems to go into reverse at idle but forward it stalls .when i get it running high rpms are ok!
boobie
Re: Johnson 225 outboard tbl
What's your idle speed when in the water in gear. A model # would also help ???
wayne robinson
when first putting in forward it dies n restarts a couple of times .noticed the idle when coming back to the dock in neutral-1000 n drops to 800 .fluctuated,n sounds off.its a 2000 ocean pro.never had a tbl til now.
Chris1956
A lot of the newer V6 motors have a shift assist switch. This switch kills spark to one bank of cylinders. On my '98 the shift assist switch is a PIA. When shifting from forward to neutral, it will sometimes stick and the motor will stall.
wayne robinson
thanks -sounds a possability.because into reverse is ok but into forward -kaput a couple of times.
wayne robinson
shift intrupter switch could be bad.u can unplug it and if ur idle is low enough wont need it
wayne robinson
shift interupter switch could be bad .had 2 go. if ur idle is low u wont need it. un plug it n see1 THEY DONT MAKE A REPLACEMENT ANYMORE.
Fact------That switch is available in my opinion.----- Just not not as a " plug and play" out of the package.------It is used on other models with different length wires.----Therefor a different part # is used.-----A competent person can easily make it work !
