jim_b_20653
Thread starter- Joined
- Apr 23, 2008
- 92
I am having an intermittant problem with my 1990 225 Johnson. It starts and idles fine, but when running at high speed it sometimes falls off plane and starts to "buck". This happens at different frequencies, sometimes I can go for 60 mins with no problem, sometimes only 5-10 minutes. When this occurs the engine continues to run and will run fine up to about 3000 RPM then it seems like the ignition is turning off and on. I have found that if I turn off the ignition and restart it fixes the problem.
My question is does this engine have some sort of safety feature that limits the RPM's? Has anyone else experienced this problem?
This engine does still use oil injection, and I recently upgraded to a new 4 wire VRO pump.
