Intoodeeep
- Joined
- Aug 13, 2011
- 64
I could really use some help and advice. I have a 1978 Johnson 235 (235TXL78RJ5002998) block with johnson 175 (J175TXCCMR7824277) carburetors and electronics but NO VRO. Its a long story how this ended up this way but it is what I am stuck with now. I have just spent the last 2 years completely rebuilding my boat from the bottom up. LITERALLY!!! I have done a bunch of research and looking around but still can't find what I am looking for. I don't want to blow this motor. This motor has been rebuilt and probably has about less than an hour on it at idle trying to make sure stuff works hear and there and fixing shift cables and shift rod adjustments and so on. SO the motor has not been broke in and I haven't put it in the water yet as I am trying to sort this stuff out. I am running 100%oil now during break in. I am waiting on a replacement regulator and rectifier now so the thing will charge and the tach will work. Heres the deal. I am concerned about the carbs and the jets. I have looked into the last year johnson made the 235 which was 85 and found that the electronics are all the same except the 2 power packs which probably have something to do with RPM limiting. I know the carbs were the same except the jets. The 78 235 carbs are very different and I don't have them. I need to know how to make the 175 carbs work with this setup. Is it just as easy to use the same jets as the 1985 235 did or are the blocks between the 1978 and 1985 different? What should I do and how should I proceed? Is there anything else that I need to do to make sure this works right? Thanks
