Subtle
Thread starter- Joined
- Oct 5, 2013
- 38
Hello, my name is Greg I'm pretty new to the forum. I have a 1992 Johnson outboard 25 hp model number J25REND. I paid $700 for this piece of junk and have taken it out two times of which I had to row my self back in. The guy I got it from said I'd get years of enjoyment out of this engine and so far none. The first time I went out the kill switch decided to shut me down and it wasn't until I unplugged it that I was able to start it again. So I fixed that. The second time. I trolled a little bit and now my bottom cylinder plug is fouling at idle. I have searched the interwebs and found that it is either the thermostat or the question goes unanswered. I have pulled my tstat and put it in a pan on the stove top and it opened. And I would assume at the right temperature as well because it opened before the water boiled and I hear these tstats run colder. Never the less it does function. I'm starting to think it's a carb or primer issue. My motor has the manual primer. I'd like to know if there is anyway to check to see if it's bad.
Other things I've done in this process.
I have a 2 Johnson 275s which run the same plug and coil.
So I've done some swapping around with that. Same issues.
I have also set my carb back to the 1 3/4 turns that was told to me in the base line starting.
I have also checked compression and got 110 which I have heard a lot of bs about. Some one told me that the actual number doesn't matter as long as the cylinders are the same and someone else told me it's way to low.
I believe the first one is correct. But what do I know I'm a auto mechanic not a outboard mechanic.
Thanks.
Thanks.
