johnson 25hp missing engine male fuel connector
joho5
I just got a 25hp Johnson motor...its a 2002 I believe.
Anyways, the male connector that is typically attached to the engine is missing. Its just a fuel line sticking out with a fuel filter.
I was just wondering if the two prong male connector is necessary.....or can I just run a fuel hose straight to the carb?
My primer bulb line detaches from the gas tank so if its not necessary I wasn't going to get one.
thanks
gm280
Re: johnson 25hp missing engine male fuel connector
thanks
Not looking up your particular engine here on iboats part section, I can't say for certainty but they still sell one for my older 1976 40 HP Johnson. So there should be one available for yours too. Personally I'd like to disconnect like it was designed to do rather then have a hanging hose...
joho5
but will it work fine like it is with the hose going straight to the carb with out a male fitting on the motor?
At least until I can get one?
Thanks
F_R
Honorary Supreme Mariner
Of course it will work if connected with no leaks or obstructions. The disconnect is just a convenience.
