johnson 25hp
rcl700
how hard is it to change the impeller on a 1991 johnson 25hp? iv got the part just not suer about doing the job. has week water presure at idle.
i have a carb kit to put on also. I think that im going to try some sea fom first.
Whoopbass
Re: johnson 25hp
It's pretty easy to do both.
Just unbolt the LU and when it drops down an inch or two and stops look in the gap and there will be a bolt on the shift rod you will have to remove.
Install impeller per instructions.
When you go to install the lower unit you will probably have to turn the fly wheel in order to line up the splines on the drive shaft.
Carb is easy as well. If you have one of those CHEAP plastic carbs make sure you don't torque the plastic covers down tight when you go to re-assemble it. They will crack.
Sea Foam isn't going to do anything for your carb. Sea Foam has never done anything for my outboards but it might help yours. Won't hurt nothing.
If you get stuck on something do a search on how to fix it if you want instant answers.
