hornblower
- Joined
- Feb 21, 2009
- 35
I'm cleaning the carb on my 1987 Johnson 30HP and have found that there is such a thing as a "needle bearing" located inside the shaft where the tip of the needle valve is. Some parts diagrams do not show this little plastic part but the carb kit I got has it inside and shows it on a diagram.
My problem, I don't know whether the old bearing is still inside the carb. I don't want to slide the new one in and chance getting it lodged in there on top of the old one. I found 1 thread where someone made a tool from a dental pick, bending a tiny hook in the end to slide into the hole and hook the old one to pull it out. I made a hook using thin stiff fish wire and was unable to hook onto anything. Looking into the hole with a flashlight I don't see anything but a smooth shiny metal shaft with a small hole at the end.
My best idea so far is to measure how much of the needle valve sticks out past the body of a carb with needle valve installed, thinking that the needle will screw into the carb body by a 1/16 to 1/8 farther if the bearing is not there to stop it. I've had a lot of help from Jasper60103 and will be getting this measurement from him but thought others might benefit from a thread on this. Chime in if you've dealt with this please.
Andy
Andy
