YellowJacket1956
- Joined
- Aug 17, 2015
- 16
I am converting my 1967 Johnson 33 from long shaft to short:
1) One part I removed was the long bolt (304135) at rear that fastens the gearcase to the exhaust housing, including the 5" housing extension. Do I need to insert a shorter bolt here if I have removed the extension, or do the 6 smaller bolts do the job? The original parts diagram does not show a shorter version.
2) In looking for the gearcase drain plug (finally found on underneath side of case) I wrongly loosened a screw (308376) labelled "PIN, pivot" on my parts diagram. What is this, and do I need to make any correction having loosened it?
Thanks for any counsel on these.
