Re: Johnson 35 hp question
I don't think you're looking hard enough.
<br />Although they only made 35hp engines for 3 years, we get questions about once a week, and many regular members here own one. It's unlikely for something to go wrong with it since it's such a dependable engine (it's survived almost 50 years afterall - show me another engine) as long as you take care of it. Lots of parts are still being made for it, and best of all they're pretty inexpensive. What's not made anymore can be found in any well-stocked junkyard or sometimes NOS on ebay. <br />The original fuel mix was 24:1 (1 quart to 6 gallons) but some of our members have chose to run less than that. I wouldn't because your engine still has a babbitt bearing on the connecting rod's small end, which needs lots of oil. But it's up to you really. Check out the oil mix faq in the engine faq forum.<br /><br />I'm pretty certain your outboard should have an electric stop. Look for two small black wires running from the engine. They're supposed to connect together to stop it.<br /><br />
'58 Super Seahorse<br />
'58 regular Seahorse<br /><br />A little more info about the lineage - in the early '50s OMC built thier largest outboard, a 37.5 CID 25hp. In 1956 they tweaked the design a bit and made it the 30hp. In '57 they increased the displacement (larger pistons), reworked the head and exhaust ports, etc, and introduced the 40.5 CID 35hp. In 1960 they increased the displacement yet more to 43.9 CID and naturally designed another head, etc for the 40hp. These were all extremely popular engines that shared the same basic design up into the 70s, with occasional revivals of old designs as economy models (30hp got reintroduced as the '62-'64 28hp, and the '57 - 58 35hp as the '65-'70 33hp)
