johnson 4.5hp seahorse cooling
OBJ
Re: johnson 4.5hp seahorse cooling
What year Adama? Or give us a model number.<br /><br />Thanks.
ED21
Master Chief Petty Officer
It spits out of the exhaust port & it streams out of the tell tail.
adama
please excuse my ignorance, when you say the tell tale is this below the water line by the prop?
ED21
No. It is a small hole underneath the engine housing. On the starboard side I believe. It is very visible when the engine is running so that you can verify water is pumping. <br />If the motor starts & you don't see the stream, the hole is clogged or the water pump isn't working. In any event I wouldn't run the motor until the problem is fixed or you risk overheating & damage.<br />The hole below the waterline is an exhaust outlet. Water probably comes out there too.<br />The screened holes above & below the cavitation plate are the water intakes. Because of their configuration, I've only run the motor in water. Not on flush muffs.
ED21
I checked on my outboard the telltall is in the center rear underneath the engine. It angles to starboard so that you can see it.<br />The exhaust port a few inches down from the powerhead is a relief exhaust when the engine idles or at low speeds. It usually spits a little water, especially at idle.<br />Be sure the water intakes are below the water.<br />The last time I replaced the impellor, the kit had instructions. It wasn't that hard to do.
adama
Thanks for the info, no water is coming out at all, im going to change the impellor, is this a common thing to go, also if it is a blockage were should i check first?
ED21
I never had the impellor go out, but I'm sure they do. I have replaced it a few times. That sounds like a good place to start.<br />I also had some sort of blockage once that a mechanic fixed. I'm not sure what he did, but it didn't cost much. He said water passages were blocked.<br />Bugs sometimes crawl inside passages & build nests, but they are so small on this motor that I never saw that happen or think that was my problem.<br />I've always liked the motor & it has generally performed well. It has never left me stranded.
