johnson 40 4 stroke lack of revs
daleburt
why will my 2005 johnson 40 not get full revs in forward gear but it will do max revs in reverse?
It was all working fine then overnight it went wrong.
any ideas would be much appreciated
Don S
Re: johnson 40 4 stroke lack of revs
This is the Yamaha, Suzuki forum, will move this over to the J/E forum
JB
You are down on power, Dalebert. It takes a lot less in R than in F
Could be a cylinder dead, throttle not opening completely, ignition retarded, bad valve, lost compression, etc.
Get a manual and do some preliminaries. Then let us know what you find.
Good luck. :)
Silvertip
Bad fuel, clogged injector, weak fuel pump, to name just a few more.
daleburt
It turned out to be a sheared flywheel key
All well now
Thanks
