Re: johnson 40 hp
Throttle position does not matter, that's completely arbitrary. What matters is that the throttle butterfly valve on the carb should *just* begin to move when those line up. You want to exaggerate the movement of the butterfly valve shaft by attaching a wire on it. The service manuals recommend crimping a stiff bit of wire into an alligator clip which you then attach to the shaft.<br /><br />I think once you get that needle secured your sneeze will go away. Do you have the packing nut which goes over the threaded part of the knob? Have you tried tightening it? If the knob is loose at all it'll leak air and cause lean running.
