fireman 757
- Joined
- May 18, 2002
- 276
Re: johnson 40, starts but won't keep running
Since both coils allow it to run on number two I would do a compression check. You might have bad rings in number one. It still could be points and condenser. You say that you just reset the points and they "look fine" Sometimes they are not. I would check all the wires carefully and look for any corrosion or loose connections from them and the condensers. There shouldn't be any play on those coils. Is your flywheel set correctly so it is not rubbing the coils?
