Nautique93
Thread starter- Joined
- Nov 10, 2008
- 40
Ive removed the 7 bolts and disconnected the gear linkage as per my service manual- apparently the gear box should now split from the exhaust housing. It is loose but seems to be held up by the drive shaft- does this need to be disconnected at the powerhead or are the splines corroded and holding it in there? If so any tricks for removal?
